speeding_infraction Posted May 8, 2023 Share Posted May 8, 2023 So I was driving home from work today and it popped out of third gear. So I had some time to test the conditions for it to do that and found out it was only when accelerating and shifting into 3rd gear that it would pop out. Downshifting from 4th or just costing in 3rd gear is not a problem. Also, when shifting into 3rd and 4th gear it will grind sometimes. Any suggestions? I also have two spare ax15 transmissions if it comes to it. Link to comment Share on other sites More sharing options...
TheSiLvAPython Posted May 9, 2023 Share Posted May 9, 2023 i do not have an answer for this but a question, would you consider parting with one of those ax15s? Link to comment Share on other sites More sharing options...
howeitsdone Posted May 9, 2023 Share Posted May 9, 2023 Need to replace your synchros. A good chance they look like this. Means that when power is applied it can't stay in gear. Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 9, 2023 Author Share Posted May 9, 2023 Ok I will probably just go ahead and change out the transmission then, as I daily this thing Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 9, 2023 Author Share Posted May 9, 2023 2 hours ago, TheSiLvAPython said: i do not have an answer for this but a question, would you consider parting with one of those ax15s? Yep, where are you located? Also, are you converting to a 4wd? Otherwise I believe the trans will not work for you unless it's for another truck not in your signature Link to comment Share on other sites More sharing options...
TheSiLvAPython Posted May 10, 2023 Share Posted May 10, 2023 On 5/8/2023 at 6:23 PM, TurboedMJ said: Yep, where are you located? Also, are you converting to a 4wd? Otherwise I believe the trans will not work for you unless it's for another truck not in your signature I am in puyallup area. I would also like to convert to 4wd. I was just talking to my uncle about doing a conversion and he said it isnt hard i just need the axle and a 4×4 transmission. Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 11, 2023 Author Share Posted May 11, 2023 7 hours ago, TheSiLvAPython said: I am in puyallup area. I would also like to convert to 4wd. I was just talking to my uncle about doing a conversion and he said it isnt hard i just need the axle and a 4×4 transmission. I am in federal way. I also have a transfer case if you want it. Will have to check what type it is. I can't meet you until after the weekend. Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 12, 2023 Author Share Posted May 12, 2023 I got the trans out and was ready to put the new one in until I noticed the ends of the primary shafts looked different. Sure enough the old one is about 4mm smaller than the new one. What can I do about this? What are my options? Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 12, 2023 Author Share Posted May 12, 2023 I came up with a solution Link to comment Share on other sites More sharing options...
TheSiLvAPython Posted May 12, 2023 Share Posted May 12, 2023 On 5/10/2023 at 6:24 PM, TurboedMJ said: I am in federal way. I also have a transfer case if you want it. Will have to check what type it is. I can't meet you until after the weekend. okay yeah that would be great. Link to comment Share on other sites More sharing options...
howeitsdone Posted May 12, 2023 Share Posted May 12, 2023 11 hours ago, TurboedMJ said: I got the trans out and was ready to put the new one in until I noticed the ends of the primary shafts looked different. Sure enough the old one is about 4mm smaller than the new one. What can I do about this? What are my options? There are two sizes of the AX-15 input shafts. Since you have an '89 did it come factory with it or was it a swap? Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 12, 2023 Author Share Posted May 12, 2023 9 hours ago, howeitsdone said: There are two sizes of the AX-15 input shafts. Since you have an '89 did it come factory with it or was it a swap? It was always an ax15. Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 12, 2023 Author Share Posted May 12, 2023 14 hours ago, TheSiLvAPython said: okay yeah that would be great. I PM'd you Link to comment Share on other sites More sharing options...
WranglerMangler Posted May 13, 2023 Share Posted May 13, 2023 Where are we meeting? I’ll bring the 8.25. Was planning on dragging it out of the shed tomorrow. Would be cool to meet 2 more CC members Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 13, 2023 Author Share Posted May 13, 2023 Haven't decided on a place yet Link to comment Share on other sites More sharing options...
WranglerMangler Posted May 14, 2023 Share Posted May 14, 2023 Sorry TurboedMJ, just throwing myself into your guy’s interaction. Lol. I have a rear diff for TheSilvAPython. I’ve been meaning to meet up with him. Link to comment Share on other sites More sharing options...
speeding_infraction Posted May 16, 2023 Author Share Posted May 16, 2023 Yeah NP lol, got my truck back on the road so I can meet whenever. Link to comment Share on other sites More sharing options...
