Bucket seat install
I finally figured out how to install my bucket seats from a 95 Cherokee in my 87 Comanche. I originally bought some of the reproduction brackets from Krustyballer but they will not work with the adjusters on these seats. I mounted some 4" x 1/4" flat stock on the floor. On the front I attached 2 pieces of 1 1/2" angle iron. I fastened the plates down using the stock seat studs from the old bench seat. Some of the studs have to be made longer. I used some 8mm x 1.25 threaded rod cut to length. The plate ends closest to the trans tunnel need to be spaced up 1" to level the plates. The inner stud in the back will match up with the hole in the new seat. For the outer hole in the bracket I drilled and tapped a hole in the plate and ran a button head bolt up to use as a stud. The front part of the seat bracket was bolted to the pieces of angle on the front plate.DSC_0088.JPG.2985e74f008683e7585146bb88ed6bd8.JPGDSC_0093.JPG.cc0f8105ea24581f5994d077f52ff439.JPG
  • 3 weeks later...
