70barracuda Posted May 3, 2023 Author Share Posted May 3, 2023 Gotta say, this is one of the worst things I've done with this truck. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 3, 2023 Share Posted May 3, 2023 That’s also the reason why I cringe at someone saying they have a “rust free” truck. It’s hiding there somewhere, you just can’t see it yet. Factory workmanship was horrendous, though probably on-par for that time period. It will be great knowing that it’s done right Link to comment Share on other sites More sharing options...
70barracuda Posted May 3, 2023 Author Share Posted May 3, 2023 8 hours ago, ghetdjc320 said: That’s also the reason why I cringe at someone saying they have a “rust free” truck. It’s hiding there somewhere, you just can’t see it yet. Factory workmanship was horrendous, though probably on-par for that time period. It will be great knowing that it’s done right Yeah it'll be better for sure, there was a surprising amount of scale but thankfully nothing made holes. Also alot of butyl left over. When you used seam sealer, was it the corners where the solder is? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 3, 2023 Share Posted May 3, 2023 6 minutes ago, 70barracuda said: Yeah it'll be better for sure, there was a surprising amount of scale but thankfully nothing made holes. Also alot of butyl left over. When you used seam sealer, was it the corners where the solder is? On mine, the top corners had solder but the lowers did not. I used seam sealer on all the overlap joints. Also used some to form a bit of a slope in the corners to get the water to flow out better. I’ll see if I can find some pics of what I did. Link to comment Share on other sites More sharing options...
