This Speedometer Cable I have...
I have a speedometer that's been acting up lately, needle bouncing. Well long story short, I ended up reattaching the cable on the instrument cluster end of things and that helped a little I suppose. I have a replacement cable that came with my truck, which by the way is an '89 2WD 4.0 auto.
The cable looks NOTHING like the one that is hooked in right now. It's shorter, the connections are both metal it seems, and there's a metal cylinder about half-way up the cable. I had to open the package to inspect it further, it's Crown Automotive part number 53009006. I understand any listing I see for it mentions 2WD but also mentions cruise control-which I do not have.
Am I right to assume that 2WD aside, due to the length, this would not be a proper replacement cable? Or is this another one of those brilliant model year part changes?
If you have a cable intended for cruise, you may be able to find the speed sensor and short extension cable to make it work in your application, even though you don't have cruise.  This is from a 1990, should be the same 87-90.
