So it looks like this piece here that looks like the regular belt guides for the front and rear
Old one is a bit smaller in terms of height and fitting in the divider bar. As seen here I replaced the one on the passenger side and it looks goofy having one of the other regular belts in it’s place
Currently working with a glass shop to see if they might be able to locate something as a replacement but apparently Chrysler and AMC(probably but I have my doubts)serviced both the glass and belt together despite being separable and not in a traditional frame.
Pretty much. Not having much luck finding anything out there, even other vehicles.
It looks pretty much like the channel/belt/guide/weatherstrip for the window that goes up and down. But just a 1/4” shorter in height putting the two together with the side that goes into the divider bar flat on the floor
