SandMountainJeep Posted April 6, 2023 Posted April 6, 2023 Converting a 1988 2wd automatic Comanche to 4wd using parts from a 1991 xj. Question is which TCU should I use? Will the 91 TCU plug into the 88 harness? Thanks for any info!
BizarroStormy Posted April 7, 2023 Posted April 7, 2023 Why are you moving over the transmission? Maybe I am ignorant of something, but they should both be AW4s so you can just move over the transfer case from the 91.
cruiser54 Posted April 8, 2023 Posted April 8, 2023 It will plug in, but note the color of the connectors. I think 91 and later was tan whereas the earlier ones were blue. Paradisexj here on CC did this conversion and ran into issues. You might search for his posts.
SandMountainJeep Posted April 8, 2023 Author Posted April 8, 2023 So it would be ok to use the 88 TCU with the 91 tranny?
SandMountainJeep Posted April 8, 2023 Author Posted April 8, 2023 On 4/7/2023 at 8:22 AM, BizarroStormy said: Why are you moving over the transmission? Maybe I am ignorant of something, but they should both be AW4s so you can just move over the transfer case from the 91. Going from 2wd to 4wd requires moving transmission as well as case.
cruiser54 Posted April 8, 2023 Posted April 8, 2023 2 hours ago, SandMountainJeep said: So it would be ok to use the 88 TCU with the 91 tranny? I'm not saying that. I'm recommending you search Paradisexj's posts.
