LT245/75R/16 on stock MJ
Never tried them on a 2WD, but still think they should fit just fine. the factory BS was about 5 inches same as ours.
I have a set on Soft 8's with 5" BS and they fit factory XJ/MJ's just fine... They have been on at least two different jeeps...
CW
The rubicon rims have less backspacing that normal xj/mj rims. There will be no rbbing on the control arms. My sons mj has a set, but with a 3" lift. Stock height would be pretty tight, those are near 32" tires. The front fenders on this truck are cut quite a bit to fit the modified TJ flares
