CMFW Posted February 21, 2023 Posted February 21, 2023 Hi. I’m an idiot. I upgraded my dash to have gauges and have been replacing sending units. I was unaware that the temperature sensor was connected to the coolant system and the engine was… freshly turned off. I cannot find how to get new coolant in this thing? I’m open to guidance. Thanks.
jpnjake Posted February 21, 2023 Posted February 21, 2023 There’s 2 places depending on if your radiator is the stock or aftermarket one, the stock renix position is here, typically ontop of a coolant bottle bracket the Other place either on an upgraded system, High output, or 2.5l I believe located here as a normal radiator cap. This time make sure that the coolant is cold, don’t want a geyser of coolant
CMFW Posted February 21, 2023 Author Posted February 21, 2023 45 minutes ago, jpnjake said: There’s 2 places depending on if your radiator is the stock or aftermarket one, the stock renix position is here, typically ontop of a coolant bottle bracket the Other place either on an upgraded system, High output, or 2.5l I believe located here as a normal radiator cap. This time make sure that the coolant is cold, don’t want a geyser of coolant Thanks. I have been a TJ guy for several years and used to pouring it down a radiator.
jpnjake Posted February 21, 2023 Posted February 21, 2023 5 minutes ago, CMFW said: Thanks. I have been a TJ guy for several years and used to pouring it down a radiator. No problem, just the stuff you have to get used to
Pete M Posted February 22, 2023 Posted February 22, 2023 1 hour ago, CMFW said: Thanks. I have been a TJ guy for several years and used to pouring it down a radiator. if you so desire, you can swap a radiator with a cap into the older trucks without changing anything else. you will still need to bleed the system. best way is actually through that same sensor hole after pointing the truck downhill (so the back of the block is the highest point). just be sure to do it when the engine is cold this time.
CMFW Posted February 22, 2023 Author Posted February 22, 2023 3 hours ago, Pete M said: if you so desire, you can swap a radiator with a cap into the older trucks without changing anything else. you will still need to bleed the system. best way is actually through that same sensor hole after pointing the truck downhill (so the back of the block is the highest point). just be sure to do it when the engine is cold this time. I managed to pull my hand away in time to not get any serious burns. anyways, system is flushed and I now have a sensor that sends to a gauge.
