Joe Dirt Posted February 18, 2023 Share Posted February 18, 2023 I know I'm all over the place and probably annoying everyone with all my questions. That being said.... do stock or polyurethane aftermarket bushings fit in rough country control arms? I know i can order them from rough country but can get them cheaper elsewhere. Thanks y'all Link to comment Share on other sites More sharing options...
89 MJ Posted February 18, 2023 Share Posted February 18, 2023 I don’t know about the answer to your question, but you’re here to learn. The best way to do that is through questions. No need to apologize for that. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted February 18, 2023 Share Posted February 18, 2023 Do what it takes to get that comanche on the road brotha My only input is folks tend to not like polyurethane bushings on a daily vehicle because extra stiffness + noise != comfort or convenience. Good luck! Link to comment Share on other sites More sharing options...
OldSch88L Posted February 18, 2023 Share Posted February 18, 2023 4 hours ago, Joe Dirt said: I know I'm all over the place and probably annoying everyone with all my questions. That being said.... do stock or polyurethane aftermarket bushings fit in rough country control arms? I know i can order them from rough country but can get them cheaper elsewhere. Thanks y'all These are the arms that came on my MJ with the unknown to me front lift. They look like Rough Country's, but many other companies have the exact same design. After some measurements on mine and some online research, they turned out to be stock bushing sizes. I got my arms blasted and powdercoated recently, and here they are with stock XJ/MJ sized bushings pressed in. Link to comment Share on other sites More sharing options...
Joe Dirt Posted February 18, 2023 Author Share Posted February 18, 2023 Nice 👍 Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted February 19, 2023 Share Posted February 19, 2023 4 hours ago, OldSch88L said: These are the arms that came on my MJ with the unknown to me front lift. They look like Rough Country's, but many other companies have the exact same design. After some measurements on mine and some online research, they turned out to be stock bushing sizes. I got my arms blasted and powdercoated recently, and here they are with stock XJ/MJ sized bushings pressed in. I also have one of those "unknown" lift kits on my comanche. If there is anyway you can share what measurements you found that were stock, that would be awesome. Many thanks from my wack job setup Link to comment Share on other sites More sharing options...
OldSch88L Posted February 19, 2023 Share Posted February 19, 2023 https://www.rockauto.com/en/moreinfo.php?pk=1284508&cc=1181584&pt=7532&jsn=868 2 hours ago, Salvagedcircuit said: I also have one of those "unknown" lift kits on my comanche. If there is anyway you can share what measurements you found that were stock, that would be awesome. Many thanks from my wack job setup Here you go. Those aren't the ones I used; I used Moog K3131, but they all have the same dimensions. Link to comment Share on other sites More sharing options...
