1JTHW6414HT135417
thousender
1987 Jeep Comanche Base
180105km on odometer
A20210621_202144.jpg.8334a3fbf401789352ee98f0a23e8a30.jpg20210621_202213.jpg.bef518051b931f2fdeb215fe4267aee0.jpg20210621_202303.jpg.3fb0e77454966475eac8d40c201c3b0c.jpg20220828_210928.jpg.3e78439eb9baf04955c80264c959a32d.jpg20221201_190139.jpg.6291959edf4961b959dea0f3bf1fb690.jpg20230121_185217.jpg.332e0bb9883e5da0f3faf7fb771afdb4.jpg
2.5l/ AX5/ NP231J / D30 w/4:10s / D35 (also w/4:10s) / SWB
Build date: Unfortunately all the info on my sticker has gone yellow and is unreadable.
Current Location: Vancouver, British Columbia, Canada
Status: Is currently off the road/uninsured but will be this coming march.
Notes: My MJ is so base that it has no audio system from factory and no passenger mirror! I plan to change that sooner rather than later. It also rocks a root beer brown exterior paired with a bandaid coloured interior.
Upgrades I have done: 4wd swap, Teraflex 2wd low range, 2" shackle lift rear, 3"spacer lift front, yj brake lines front, yj lifted brake line rear, extended load sensing unit arm, extended swaybar endlinks, Rancho RS5000 shocks rear, Stock JK shocks front, 31's on base cherokee rims, tow hooks, factory underhood light, v8 ZJ steering, power steering, full gauge cluster, K&N filter, courtesy lights, Euramtec b-pillar lights, new headliner and sunvisors, ZJ pillowtop bucket seats, wagoneer dash, some of cruisers renix tips, new fuel tank, new sending unit... am in the middle of installing an ACC carpet
Upgrades I plan to do: Tonneau cover, full length center console out of a 97+ to obtain cup holders, tilt steering column, interval wipers, cruise control, a set of bassett or polished AR172 rims, sliding rear window, period correct buckets (ideally from a wagoneer), fog lights, rough country control arms...
Owner history: I purchased this comanche from my shop teacher who had it donated by (I believe) the original owner.
*X1
-YY
APA MONOTONE PAINT PACKAGE
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DDJ 5SPD MANUAL TRANS
EPD ENGINE - 2.5L I4 TBI GAS
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JDA SPEEDOMETER - 140 KILO PRIMARY
KQJ
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAG
PYN
QYN
TBG SPARE TIRE - COMPACT
WMC BASE WHEEL DRESS - UP (INCLS TRIM RING)
Build date 3/26/87
Body code TL61
Sold by DEER LAKE PLYMOUTH CHRYSLER LT,  VANCOUVER (BURNABY) BC
