Armyvet25 Posted January 29, 2023 Posted January 29, 2023 1986 Jeep Comanche XLS 2.8L V6 5 speed Ax5 4x4 Long Bed I'll update this thread with additional details
eaglescout526 Posted January 29, 2023 Posted January 29, 2023 *ZZ -ZZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AGR AGY AJT RADIO PREP GROUP AJZ CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket MWB SPORT BAR NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 10/17/85 Body code JP62
Armyvet25 Posted January 30, 2023 Author Posted January 30, 2023 is this info purely based on the vin?
eaglescout526 Posted January 30, 2023 Posted January 30, 2023 Yes. This info is unique to your VIN. I can’t pull these out of thin air like my co workers think with parts they can’t find haha.
Armyvet25 Posted January 30, 2023 Author Posted January 30, 2023 23 gal fuel tank huh...me likey, and thanks. Gotta check axle ratio and look for any data tags.
eaglescout526 Posted January 30, 2023 Posted January 30, 2023 Yeah some of them are wrong so take them with a grain of salt as Pete says. The axle ratios is what we seem to find to be commonly wrong with the build sheets. Except the D44, that seems to show up right.
Armyvet25 Posted January 30, 2023 Author Posted January 30, 2023 since original interior, possible build sheet under seat, or to new for them?
eaglescout526 Posted January 30, 2023 Posted January 30, 2023 Well 86 “red” interior is weird. It looks like you have the mid garnet that is about to go to cordovan for 87. But you also have an early 86 which should be more garnet. It looks original to the MJ and probably is.
Pete M Posted January 30, 2023 Posted January 30, 2023 4 hours ago, armyvet25 said: 23 gal fuel tank huh...me likey, and thanks. Gotta check axle ratio and look for any data tags. yeah, always take them with a grain of salt. technically that said "20 gal" which is not an MJ size at all, but so far all I've been able to confirm that when it returns a 20, it's a 23. it's easy to check, as the 23 has 3 straps, while the 16 only has 2.
Pete M Posted January 30, 2023 Posted January 30, 2023 oh, and the build sheet could be in the door panel, under the dash on the pass side, or behind the carpet rear panel. or not there at all.
Armyvet25 Posted January 30, 2023 Author Posted January 30, 2023 1 minute ago, Pete M said: oh, and the build sheet could be in the door panel, under the dash on the pass side, or behind the carpet rear panel. or not there at all. Thanks
eaglescout526 Posted January 30, 2023 Posted January 30, 2023 14 minutes ago, Pete M said: 16 only has 2. Youre thinking the 18 Pete under the short beds. Mine had the 16 gallon and still used the three straps before converting to the 23 gallon tank. But that being said the 20 gallon tank code is more common to XJs and our tank code probably got replaced at some point after the MJ was phased out.
Pete M Posted January 30, 2023 Posted January 30, 2023 wait, are the 23 and 16 the same tank but with a different length vent tube to cut back the volume it holds? or am I thinking of another Jeep? @eaglescout526
eaglescout526 Posted January 30, 2023 Posted January 30, 2023 1 hour ago, Pete M said: wait, are the 23 and 16 the same tank but with a different length vent tube to cut back the volume it holds? or am I thinking of another Jeep? @eaglescout526 That is correct. Both tanks are the same but the neck inside the tank the dumps the fuel in is longer and stops the nozzle at the fuel pump from putting more fuel in because it’s the full 16 gallons.
Armyvet25 Posted January 30, 2023 Author Posted January 30, 2023 33 minutes ago, eaglescout526 said: That is correct. Both tanks are the same but the neck inside the tank the dumps the fuel in is longer and stops the nozzle at the fuel pump from putting more fuel in because it’s the full 16 gallons. That's a YJ thing too, write ups on removing the extra and gaining more fuel.
