1JTWL6599GT060068
Armyvet25
*ZZ
-ZZ
ADA LIGHT PACKAGE
ADL SKID PLATE GROUP
AGR
AGY
AJT RADIO PREP GROUP
AJZ
CGW
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
CUF FULL LENGTH FRONT CONSOLE
DDQ Transmission - 5-Speed Manual
EFB ENGINE - 2.8L GM 6CYL
GAC ALL WINDOWS - TINTED GLASS
GFD SLIDING RR WINDOW
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JGB Clock - Digital
LBB COURTESY LAMPS (BELOW PANEL)
LMA HALOGEN HEADLAMPS
LPE EXTERIOR CARGO LIGHT
MBJ Bumper - Front, Black
MD8 Delete Front License Plate Bracket
MWB SPORT BAR
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NFA TANK - 23 GAL FUEL
SBA POWER STEERING
SCG LEATHER STRG WHEEL - EURO/SPORT TYPE
WJD WHEELS - 15 X 7.0 STYLED STEEL
Build date 10/17/85
Body code JP62
4 hours ago, armyvet25 said:
23 gal fuel tank huh...me likey, and thanks. Gotta check axle ratio and look for any data tags.
yeah, always take them with a grain of salt. :L:   technically that said "20 gal" which is not an MJ size at all, but so far all I've been able to confirm that when it returns a 20, it's a 23.  it's easy to check, as the 23 has 3 straps, while the 16 only has 2.
14 minutes ago, Pete M said:
16 only has 2.
Youre thinking the 18 Pete under the short beds. Mine had the 16 gallon and still used the three straps before converting to the 23 gallon tank. But that being said the 20 gallon tank code is more common to XJs and our tank code probably got replaced at some point after the MJ was phased out.
1 hour ago, Pete M said:
wait, are the 23 and 16 the same tank but with a different length vent tube to cut back the volume it holds?  or am I thinking of another Jeep?  @eaglescout526
That is correct. Both tanks are the same but the neck inside the tank the dumps the fuel in is longer and stops the nozzle at the fuel pump from putting more fuel in because it’s the full 16 gallons.
That's a YJ thing too, write ups on removing the extra and gaining more fuel.
