What do u all use for vacuum lines hard or soft?
Ive tried the local dealer and found out its discontuied. Ive tried napa and no go there too.
Any ideas what I should try to use for all these vac/lines?
Ive notice there are many black soft and hard lines I'm guessing the hard needs to stay hard! this is for a 89 comanche and 91 cherroke
its snowing up here
Rubber line is fine when it's new, but if it softens with age it collapses and then you get no vacuum. I prefer to use steel or copper tubing (copper is much easier to bend, but more expensive and you won't find it at an auto parts store, you probably have to do to a plumbing supply house), and just use a short elngth of rubber to make the connections at the ends.
