86FUBAR Posted December 12, 2007 Share Posted December 12, 2007 all this talk about tranies made me wonder what is the real difference between the two are, can anybody pleas in form me ? Link to comment Share on other sites More sharing options...
offroader461 Posted December 12, 2007 Share Posted December 12, 2007 AX-5 was used behind the 2.8 and the 4 banger AX-15 was put behind the 4.0L different internal gear setups to handle the diffence in power i believe...just a guess Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 12, 2007 Share Posted December 12, 2007 all this talk about tranies made me wonder what is the real difference between the two are, can anybody pleas in form me ? ax5 ax15 they're visually similar except size...the ax5 is shorter than an ax15, and quite a bit less durable. the ax5 was usually mated to a gm 60 degree bellhousing, whereas the ax15 was usually mated to a amc (4.0) housing. the ax15 was available in early dakotas with a gm 60 degree bellhousing Link to comment Share on other sites More sharing options...
86FUBAR Posted December 12, 2007 Author Share Posted December 12, 2007 ya i kinda figured that may have been it but my chiltons just said that the ax15 was a" high capacity" , :dunno: thanx Link to comment Share on other sites More sharing options...
offroader461 Posted December 12, 2007 Share Posted December 12, 2007 would and AX15 out of a 4cylinder dakota bolt up to the 4.0??? Link to comment Share on other sites More sharing options...
1986Comanche Posted December 12, 2007 Share Posted December 12, 2007 would and AX15 out of a 4cylinder dakota bolt up to the 4.0??? No, it will not. The bellhousings are completely different. Link to comment Share on other sites More sharing options...
offroader461 Posted December 12, 2007 Share Posted December 12, 2007 bummer...too bad i had a line on one for $30 bucks out of a totaled 95 Dakota and just recently rebuilt too w/paperwork...oh well guess i can wait for another Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 12, 2007 Share Posted December 12, 2007 would and AX15 out of a 4cylinder dakota bolt up to the 4.0??? No, it will not. The bellhousings are completely different. what he said. if you find an ax15 from a dodge dakota, I want the bellhousing. I'd give you a 4.0 bellhousing to go with it, I'd even find you an external slave one (hint, I need an ax15 bellhousing from a dakota so I can put an ax15 behind the 3800) Link to comment Share on other sites More sharing options...
offroader461 Posted December 12, 2007 Share Posted December 12, 2007 this one has a 4cylinder housing...would that work for you?? Link to comment Share on other sites More sharing options...
1986Comanche Posted December 12, 2007 Share Posted December 12, 2007 would and AX15 out of a 4cylinder dakota bolt up to the 4.0??? No, it will not. The bellhousings are completely different. what he said. if you find an ax15 from a dodge dakota, I want the bellhousing. I'd give you a 4.0 bellhousing to go with it, I'd even find you an external slave one (hint, I need an ax15 bellhousing from a dakota so I can put an ax15 behind the 3800) What do you have behind your 3800 now? An AX-5? Is the 3800 V6 a 60 degree V6? Just wondered. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 12, 2007 Share Posted December 12, 2007 would and AX15 out of a 4cylinder dakota bolt up to the 4.0??? No, it will not. The bellhousings are completely different. what he said. if you find an ax15 from a dodge dakota, I want the bellhousing. I'd give you a 4.0 bellhousing to go with it, I'd even find you an external slave one (hint, I need an ax15 bellhousing from a dakota so I can put an ax15 behind the 3800) What do you have behind your 3800 now? An AX-5? Is the 3800 V6 a 60 degree V6? Just wondered. yes and yes. check the build thread in MJ projects. Link to comment Share on other sites More sharing options...
