  • 3 weeks later...
  • 3 weeks later...
On 12/13/2022 at 4:33 PM, SoCalJeepComanche said:
Head down to your local pick-n-pull.  They are the same ones used on Cherokees 84-01 IIRC.
Same 1986-2001.  1984-85 XJs used a single, center mounted windshield sprayer nozzle that doesn't interchange with the more common 1986-2001 dual nozzle version.
Interesting.  I’m sure it can be retrofitted with the dual hose, right?
The single nozzle itself is different from the dual nozzle.  You would have to exchange the entire cowl panel.  I've never tried it, but I would think the later cowl panel with the dual sprayers would be a direct bolt on for the 84-85 XJs.
Here is a pic of the 84-85 single nozzle panel in tan, compared to the dual nozzle in red.
