GonzoTheGreat Posted October 24, 2022 Posted October 24, 2022 '89 Jeep Comanche 2.5L, AW4 (I think), 2 wheel drive This is my new daily driver in Worcester county, MA I am the proud 3rd owner of this little guy. It had 50,751 miles when I bought it. It's an old man special, with no factory options besides the automatic, not even power steering. I will probably start a build thread with more details. It is in excellent shape. It came with a folder full of maintenance receipts and even some original paperwork from the dealership.
The86manche Posted October 25, 2022 Posted October 25, 2022 Ohhh a unique one! That should be an aw4. Which makes it quite rare as that bellhousing is very specific to the 2.5 and the gears should be 4.56. Also I'm in lowell! Hello
GonzoTheGreat Posted October 25, 2022 Author Posted October 25, 2022 oh hell yeah! I'm in Millbury (outside of worcester). I'm in Lowell quite a bit for work. I didn't realize the bellhousings were different from the 2.5 to the 4.0. thanks!
eaglescout526 Posted October 29, 2022 Posted October 29, 2022 *D1 TRIM STYLE D1 - CLOTH BENCH -Q8 131 Zone 31-Boston 1AA U.S. Dealer Retail 3BK Customer Preferred Discount 5AL Low Series Tracking APA MONOTONE PAINT BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKJ BLACK VINYL FLOOR COVERING CSR PASSENGER ASSIST HANDLES DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DGS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHA LOCK-UP TORQUE CONVERTER DHT SHIFT-ON-THE-FLY,P/TIME T/CASE DMG 3.55 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS EPD ENGINE - 2.5L I4 TBI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GNA REAR VIEW DAY/NIGHT MIRROR GRV LEFT MANUAL MIRROR GUA OPEN HCD DO NOT USE - SEE HCA JAA INSTRUMENT PANEL JAZ DO NOT USE - SEE JP, KA CLASSES JBF INSTRUMENT PANEL BLACK BEZEL JCA 85 MPH PRIMARY SPEEDOMETER JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF SEAT BELT ALERT-DRIVER SEAT ONLY LBC GLOVE BOX LAMP LCJ DOME/READING LAMP B-PILLAR LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Solid Rear Window MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PA2 STERLING SILVER M CC PRIMARY PAINT - HA2 QA2 STERLING SILVER MC SECONDARY PAINT - HA2 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SAA Manual Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEA No Optional Sales Codes YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z57 Left Front Spring Group Vii Z76 Right Front Spring Group VI Build date 1/23/89 Body code TL61 Sold by FALVEY'S INC, NEW LONDON CT
WAEMID IV Posted May 28, 2025 Posted May 28, 2025 Do you still have this truck? Have you ever been able to verify the gear ratio? There's no way it has 4.56 gears
GonzoTheGreat Posted May 28, 2025 Author Posted May 28, 2025 9 hours ago, WAEMID IV said: Do you still have this truck? Have you ever been able to verify the gear ratio? There's no way it has 4.56 gears Yep! Still got it. 4.56 confirmed
