Would that writeup be Comanche specific enough to be here? or is it so easy it doesnt require a writeup? I was about to start it and decided to hold off...
I was going to do a doubler but everybody says it won't go under the stock floorboard. Have you looked into this or are you planning on cutting the floor?
Chev built the trans. Motor was @400 HP
Poor thing must have been really worn out. 400HP at what kind of torque? What exactly broke?
I stomped on it and downshifted to second, taking out the planetary and front pump at the same time. The Monza was travelling on an angle up the highway at the time with wheels spinning.
