bgred2 Posted December 8, 2007 Share Posted December 8, 2007 1989 MJ, 4.0, auto The temp got up in the high 30's today, so I thought I would tinker with my Jeep a little. Checked the voltage's on my throttle position sensor and found that it needed some adjusting. Tried to loosen the top torx bolt holding the sensor on and it promptly broke off at the head. The bottom one came out fine, so I pulled the sensor off, got some vise grips on the broken bolt, and of course broke it off right at the throttle body. Hauled out the easy outs and drills and started drilling. Yup you guessed it, broke the freakin drill off about a quarter inch in. Put everything back together with one bolt holding the sensor on, adjusted the sob to spec., and I am getting ready to head for the bar (in the wife's Altima) . Does anyone have any suggestions for my best course of action now.............other than a designated driver? Link to comment Share on other sites More sharing options...
Twisty Posted December 8, 2007 Share Posted December 8, 2007 Probobly the easiest thing to do would be to locate a new one (I have 2 spares ;)) and swap the sensors over. Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 8, 2007 Share Posted December 8, 2007 1989 MJ, 4.0, auto The temp got up in the high 30's today, so I thought I would tinker with my Jeep a little. Checked the voltage's on my throttle position sensor and found that it needed some adjusting. Tried to loosen the top torx bolt holding the sensor on and it promptly broke off at the head. The bottom one came out fine, so I pulled the sensor off, got some vise grips on the broken bolt, and of course broke it off right at the throttle body. Hauled out the easy outs and drills and started drilling. Yup you guessed it, broke the freakin drill off about a quarter inch in. Put everything back together with one bolt holding the sensor on, adjusted the sob to spec., and I am getting ready to head for the bar (in the wife's Altima) . Does anyone have any suggestions for my best course of action now.............other than a designated driver? it'll still run without the sensor connected, so don't think your truck will fall apart without it perfect, but it's good to have it adjusted right, i would just drive it normal and check it everyonce in a while and try to get your hands on a throttle body Link to comment Share on other sites More sharing options...
oldjeep Posted December 8, 2007 Share Posted December 8, 2007 Probobly the easiest thing to do would be to locate a new one (I have 2 spares ;)) and swap the sensors over. Yup $19 at the local u-pull with all the sensors attached. Link to comment Share on other sites More sharing options...
oldjeep Posted December 8, 2007 Share Posted December 8, 2007 it'll still run without the sensor connected, so don't think your truck will fall apart without it perfect, but it's good to have it adjusted right, i would just drive it normal and check it everyonce in a while and try to get your hands on a throttle body You don't want to drive around with the TPS disconnected on an AW4 equipped truck. It really screws up the shifting Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 8, 2007 Share Posted December 8, 2007 it'll still run without the sensor connected, so don't think your truck will fall apart without it perfect, but it's good to have it adjusted right, i would just drive it normal and check it everyonce in a while and try to get your hands on a throttle body You don't want to drive around with the TPS disconnected on an AW4 equipped truck. It really screws up the shifting good point, mine's a stick. :oops: but you don't WANNA drive around like that anyways, odd backfiring issues. ;) Link to comment Share on other sites More sharing options...
Twisty Posted December 9, 2007 Share Posted December 9, 2007 Actually, come to think of it, my MJ only has 1 screw holding on the TPS. I keep meaning to get another, because over time the TPS becomes un-adjusted :roll: Link to comment Share on other sites More sharing options...
Eagle Posted December 9, 2007 Share Posted December 9, 2007 Both bgred2 and Twisty are in Massachusetts, so I'll suggest you both head over to Henry's in Blackstone, MA. It's a combination u-pull and "they pull" yard. I haven't been there for awhile, but they generally have a huge area of XJs and MJs back in the u-pull section of the yard. Link to comment Share on other sites More sharing options...
