Classy Comanche Posted September 2, 2022 Share Posted September 2, 2022 Had new plugs, wires and distributor cap installed today. The truck is so much more responsive. But it idles higher and higher cranks. Is that normal? Does a engine take time to get used to new parts as such? Also here's two videos of the truck starting and the truck idling then being shut-off. Does it every start when I drive it 20220902_185159.mp4 20220902_185342.mp4 Link to comment Share on other sites More sharing options...
BizarroStormy Posted September 7, 2022 Share Posted September 7, 2022 That sounds normal to me (at least mine does that ). I'm pretty sure the idle air control solenoid opens up when starting to make it easier to start, then quickly cranks down to establish idle. Does your truck have a tach, what is it idling at in park after it warms up? Link to comment Share on other sites More sharing options...
Classy Comanche Posted September 7, 2022 Author Share Posted September 7, 2022 Well I actually found the fix for it. So it ended up being literally two small disconnected vacuum hoses. And the high crank and rpm is gone 100% and no sadly I have no heat gauge or tach. I have a gas gauge, speedometer and the rest are like lights Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 8, 2022 Share Posted September 8, 2022 The startup RPM is normally coolant temp dependent. It’s normal to have an idle up at startup for a few seconds. The vacuum leak would definitely idle it up though across the board. Link to comment Share on other sites More sharing options...
Classy Comanche Posted September 8, 2022 Author Share Posted September 8, 2022 Yeah if you guys go to "88 Pioneer high rev when cranking" you'll see better videos of what I was experiencing. Link to comment Share on other sites More sharing options...
