Muncher Posted August 22, 2022 Share Posted August 22, 2022 So I bought another mj. It's a 95 swapped 86 long bed. Some interesting wiring but it runs great. We all know My luck though it blew the cps, coil and radiator on my way home from getting it. Fixed it all last night. Here's some pictures of it. Link to comment Share on other sites More sharing options...
Muncher Posted August 22, 2022 Author Share Posted August 22, 2022 Snapchat-1397063193.mp4 Link to comment Share on other sites More sharing options...
Muncher Posted August 28, 2022 Author Share Posted August 28, 2022 Well I went from one electrical problem mj to another! Luckily this one still runs. My current problem I'm facing is it will randomly turn off with no hesitation and sometimes it will do it right after doing it once or I can go 20 miles before it does it again. Thinking it's either the cam position sensor or one of the grounds. Either way I'll probably just replace them all. Link to comment Share on other sites More sharing options...
jpnjake Posted August 28, 2022 Share Posted August 28, 2022 1 hour ago, Muncher said: Well I went from one electrical problem mj to another! Luckily this one still runs. My current problem I'm facing is it will randomly turn off with no hesitation and sometimes it will do it right after doing it once or I can go 20 miles before it does it again. Thinking it's either the cam position sensor or one of the grounds. Either way I'll probably just replace them all. Aw man you can’t catch a break, hopefully it’s something easy to fix here’s a couple of pictures from when we were picking up the Chief Link to comment Share on other sites More sharing options...
Muncher Posted September 2, 2022 Author Share Posted September 2, 2022 Did up my floors. First coat at least. After this I'll ad some kilmat Link to comment Share on other sites More sharing options...
Muncher Posted September 14, 2022 Author Share Posted September 14, 2022 Mech fan pulley bolts strip out and fry belt. Replaces whole bracket and gets the studs I'm suppose to have belt#2 Power steering pump snaps alignment bolt and shreds belt #2 Just fixed that and got my 3rd belt and now. Boom My alternator took half the bracket with it and I get towed home. What a life Link to comment Share on other sites More sharing options...
Muncher Posted September 15, 2022 Author Share Posted September 15, 2022 Got a tdi, Leaving the jeep life. Jk swaping the tdi motor into the mj. Coming by the end of 2023 Snapchat-1568792664.mp4 Link to comment Share on other sites More sharing options...
