Dandxj Posted August 16, 2022 Share Posted August 16, 2022 1990 4.0L - I know that the ECU controls the IAC Motor, but does anyone know the voltage of the signal? Is it 12V or some reduced voltage? I am trying to figure out why the motor pintle is staying in the retracted position(high idle). Yes it is clean, new BWD IAC and TB is clean. I had the same issue with old IAC, hence the new one. I have to put a piece of duct tape over the passage on top of TB to keep the idle down. Thanks Link to comment Share on other sites More sharing options...
cruiser54 Posted August 17, 2022 Share Posted August 17, 2022 How is the GROUND at that connector? I'm gonna guess it's 12 volt. Link to comment Share on other sites More sharing options...
Ωhm Posted August 20, 2022 Share Posted August 20, 2022 Check B+ Latch Relay circuit. Relay supplies 12vdc for IAC Motor via the ECU. Link to comment Share on other sites More sharing options...
Dandxj Posted August 20, 2022 Author Share Posted August 20, 2022 Thanks - I am seeing only 10 volts at the IAC. So somewhere I am losing 2 volts. I will start by pulling the ECU and cleaning the connectors. Link to comment Share on other sites More sharing options...
