99 Cherokee Parts?
Could anyone provide a list of potential upgrade components that could be obtained from a 99 4 DR Cherokee 4.0 to be fit onto a 91 4.0 HO?
I have seen multiple threads discussing various components, but I may have access to a parts car, and would like to get whatever would be of use.
Things so far:
The doors - or the full window panels/hardware.
Mirrors.
Coolant Tank.
Brake Booster.
Master Cylinder.
Intake Manifold - although too late, as someone else got to the entire engine.
Front Clip - also too late, as is was wrecked from the front.
Distributor - also too late.
Interior
Heater core
Seats
Trac bar?
Sway bar?
Front Coils?
Rear Leafs?
Hitch assembly
What am I missing?
OK. Scratch the receiver hitch - thanks Pete.
Also just found a thread indicating the stock XJ springs are same as the MJ - scratch that.
And... maybe not the Track bar - or the front sway;  scratch those. Though I swear I saw a thread where XJ front suspension was transported to an MJ - but have found 4 links now indicating  they are the same. So maybe my... missing link was just replacing like for like.
Completely different. Almost everything transfer case & doors forward is identical. Transfer case back is all different except axle.
Actually axle is different too. On a 99 it could be a Chrysler 8.25, and if it was a Dana 35 the spring perches are on the top of the axle where the MJ is on the bottom.
