Hi hoping to get more posts on this. Getting ready to buy an 87, truck is currently stuck in 4 wheel low, anyone else with this problem? The shifter is stuck in 4wheel low. Also truck is only five minutes from hone, worse case scenario if I drive it slow should it be ok?
Try removing the linkage at the t-case and see if you can move the piece on the t-case. If the t-case moves adjust the linkage or switch to a Boostwerks or Azzys linkage.
