Air conditioner help
Here we go,  been searching,  but haven’t found the answers.
We are adding a/c to 1988 4.0 that has a remanufactured Jasper in it from a 1995.  We got the whole system out of a 1996 minus the under hood wiring and correct idler pulley.  Learning quick how parts changed year to year.
The “dilemma” we are in is the 1996 compressor doesn’t mount the same as the 1988.  There isn’t a idler bracket on the power steering side.  Would it be better to buy a 1988 style compressor,  or try to source a idler bracket from a later model?  I don’t mind buying the compressor,  as this one is already older from a junkyard.  We already replaced heater core and evaporator under dash.  Any suggestions?
5 minutes ago, Strokermjcomanche said:
You can swap to the 96 fan bracket so you can use a 96 compressor and use the 88 belt . You don’t need the 96 idler pulley , the power steering pump will tighten the belt
That’s what we did so far,  now we will have to reroute the belt(?).  The belt from the ‘88 won’t clear the thermostat and hoses the way it was.  Is there an alternate way to route it?
1 minute ago, Strokermjcomanche said:
I forgot about the idler pulley. You’re right
Would you recommend using an ‘88 style compressor?  It would allow for the pulley.  This things starting to feel like a Johnny Cash song…..   one piece at a time😂
6 minutes ago, Strokermjcomanche said:
Possibly, I don’t know if the newer hoses would work .
That’s one of my concerns.   I have the newer style (‘96) evaporator,  expansion valve and dryer that I bought new.   I wouldn’t be opposed to buying new hoses and the older style expansion valve,  dryer and compressor if need be.   I just want it to be done the most efficient way.
Yeah this could be an issue. You can always swap to the Renix compressor but you might run into the issue of hose fitment like stroker said. Chrysler was pretty non standard with AC parts in HO years. Like 94 could have one hose set and then 95 can have completely different hoses.
