has anyone found a suitable replacement clock?
I managed to get the instrument cluster out.  With the instrument fuse out, the cab lighting harness disconnected, and  the lights off, my power lead to the lighting shows continuity with ground.  As I read it, that is definitely a short in the supply wiring somewhere between the fuse block and the instrument lights.
....oops. I was using the 88 Electrical Manual. No Radio/LCD Clock Illumination Relay. Somehow now I think I've already answered this once. ...oops again. I should know better.
I have a workaround that I like.  I have run a new wire from the lights and am going to use a piggyback fuse to hook it in to the instrument light fuse location.  with no fuse in the original socket, I bypass the problem entirely.  My clock light can stay on and bright.
