88mjsally Posted June 15, 2022 Share Posted June 15, 2022 Harnesses: 89 4.0 manual 4wd dash and engine harness- needs a few fuse block terminals replaced but the Jeep it came from did run good. No c101 connector since it’s a 89 harness. $200 89 4.0 auto 4wd engine harness. In good shape. No c101 connector since it’s a 89 harness. $125 88 4.0 auto 4wd engine harness. In good shape, it does have the c101 connector. $100 Link to comment Share on other sites More sharing options...
Muncher Posted July 5, 2022 Share Posted July 5, 2022 Would the 89 harness work for a 87? And what are the fuse blocks that need to be replaced Link to comment Share on other sites More sharing options...
88mjsally Posted July 7, 2022 Author Share Posted July 7, 2022 On 7/5/2022 at 10:25 AM, Muncher said: Would the 89 harness work for a 87? And what are the fuse blocks that need to be replaced Yea it will, you’ll just need to replace some of the terminals as a few are broken. The dash harness is different than the mj one though Link to comment Share on other sites More sharing options...
tugboat95 Posted August 27, 2022 Share Posted August 27, 2022 Do you still have the 89 4x4 automatic harness? Link to comment Share on other sites More sharing options...
88mjsally Posted August 28, 2022 Author Share Posted August 28, 2022 3 hours ago, tugboat95 said: Do you still have the 89 4x4 automatic harness? Yea I believe I still have it Link to comment Share on other sites More sharing options...
Archived
