I've had this project for a while.  Making slow progress on it.
It's a 1997 F250HD 4x4 with the 7.3 diesel.  It has some body damage and the engine wasn't running.  But I got it for a steal.
Turns out the #2 cylinder was toast.  160 PSI compression when the rest were around 360.  So it sat for a bit.  I did post a pic of the MJ with the engine in the back.  It sits... a little low with that much in the back.
I have a donor for the sheet metal and other bits.  It has a running and driving 460/E4OD 2wd powertrain that will be for sale.
I also swapped in a Dana 60 from an F350 to replace the TTB Dana 50 that was in it.  That's a lot easier to do with no engine in the way.
I found myself with a couple days off so i got the 7.3 torn down and ready for the machine shop.
The MJ makes for a good  workspace for that.
I'm going to be working on this over the summer.  It should end up being a good tow rig to haul the MJ when I get it done next year.
  • 3 months later...
And yes.  I hve considered putting the powerstroke into the MJ it's sitting next to.
I just don't want to do all the fab work to make it fit...
I did some more work getting the truck ready to receive the engine.  I'm swapping over some sheet metal on the front clip from a donor (in the background).  And it's easier to access the engine bay with stuff out of the way so with some help I pulled the hood, cowl and driver's side fender.
PXL_20220925_172105140_MP.jpg.9943757662dfc2a1cf7d4ac0a0a34af2.jpgPXL_20220925_172243018.jpg.5d3316d55bc1489564de7e8951b5fa11.jpg
On 9/26/2022 at 9:48 AM, derf said:
man, I wish I could do that to an MJ  :(   So much access!!
Yeah, it is pretty nice.  I'm not looking forward to that part of my MJ build when that gets rolling.
Passenger side brake drum wasn't cooperating so I convinced it to come off.  Them I found out why.  Fortunately, this was discovered as I was already rebuilding the rear axle anyway.
PXL_20221009_005332077.jpg.8cb624c3eeca16ab0a17f98d423aade6.jpgPXL_20221009_003348412.jpg.2fe5f76a08cf9e111193ecaa4644a1ee.jpg
  • 3 weeks later...
