youngfred Posted May 18, 2022 Share Posted May 18, 2022 ... Dangme. I keep getting the same results, as I call around. "Bosch says - 69302 - has/is - Discontinued ???" Any help here would be appreciated. youngfred Link to comment Share on other sites More sharing options...
gogmorgo Posted May 19, 2022 Share Posted May 19, 2022 I still see a bunch of online retailers claiming to have them in stock. No word yet on an HO sending from MTS yet I guess? There were always other options that could be made to work, the Bosch one just happened to be better than most. And in most cases the only concern was getting it to fit in the sending unit. I might honestly just take the whole sending unit into the parts store and try to test fit whatever pump they happen to have on hand. Link to comment Share on other sites More sharing options...
youngfred Posted May 19, 2022 Author Share Posted May 19, 2022 1 hour ago, gogmorgo said: I still see a bunch of online retailers claiming to have them in stock. No word yet on an HO sending from MTS yet I guess? There were always other options that could be made to work, the Bosch one just happened to be better than most. And in most cases the only concern was getting it to fit in the sending unit. I might honestly just take the whole sending unit into the parts store and try to test fit whatever pump they happen to have on hand. ... I started out with - No Start and no Fuel Rail Pressure. Never kept more that a couple of gallons in the tank because of our 'modern gas'. Thought maybe the fuel pump overheated and failed. No leaks on the Fuel Pressure Regulator but with no Fuel Rail Pressure, I suspected Fuel Pump/Fuel Pressure Regulator. Started with the Fuel Pump. As I removed the FP the bottom Rubber Support (Red Arrow)came out in pieces(modern fuel) ??? The Sock was still on the pump. The upper (slotted one in the photo) looks okay but maybe fuel did not get up to that level - maybe??? I put power to the pump on the bench and it quietly purred but I have not tested it, for pressure. I am also going to change out the FPR. ~ Came across a Bosch pump, in Canada. Will try tomorrow. youngfred Link to comment Share on other sites More sharing options...
youngfred Posted May 19, 2022 Author Share Posted May 19, 2022 13 hours ago, gogmorgo said: ...I still see a bunch of online retailers claiming to have them in stock. ... Can you provide which retailers show stock ??? I cannot find any with stock. Thanks. youngfred Link to comment Share on other sites More sharing options...
gogmorgo Posted May 19, 2022 Share Posted May 19, 2022 1 hour ago, youngfred said: ... Can you provide which retailers show stock ??? I cannot find any with stock. Thanks. youngfred All I did was google the part number, but here's some results off the first page that still show stock. https://www.thewrenchmonkey.ca/products/auto-parts/bosch/69302/ https://www.vividracing.com/bosch-electric-fuel-pump-p-154553698.html https://www.globalindustrial.com/p/electric-fuel-pump-69302-vm-auto Whether they actually have stock or not I couldn't tell you, and I've never actually dealt with any of them. Link to comment Share on other sites More sharing options...
youngfred Posted May 19, 2022 Author Share Posted May 19, 2022 3 hours ago, gogmorgo said: All I did was google the part number, but here's some results off the first page that still show stock. https://www.thewrenchmonkey.ca/products/auto-parts/bosch/69302/ https://www.vividracing.com/bosch-electric-fuel-pump-p-154553698.html https://www.globalindustrial.com/p/electric-fuel-pump-69302-vm-auto Whether they actually have stock or not I couldn't tell you, and I've never actually dealt with any of them. ... Thanks for those. All show 'In Stock' but in talking to them, they all say the pumps are Backordered. youngfred Link to comment Share on other sites More sharing options...
gogmorgo Posted May 19, 2022 Share Posted May 19, 2022 💩 I seriously hate when websites do that. Honestly it’s false advertising, lying about your ability to procure something. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 19, 2022 Share Posted May 19, 2022 21 hours ago, youngfred said: Never kept more that a couple of gallons in the tank because of our 'modern gas'. Running a consistently low tank can shorten the life of your pump. Also allows more room for water vapor which is worse than ethanol imo. Link to comment Share on other sites More sharing options...
Big Dan Posted July 16, 2022 Share Posted July 16, 2022 Anyone have any luck locating a source? Link to comment Share on other sites More sharing options...
