1J7FJ26L8KL412945
Heinri_k
1989 Jeep Comanche
4.0l engine from I am told a 1991 Cherokee. Original engine was 2.5l I believe.
4wd with NP231 transfer case.
5 speed manual AX15. Not the original either I suspect.
Short bed and charcoal grey/black.
Dana 30 in the front, 35 in the rear.
I was also told that the dashboard is from a Cherokee, seats and added center console are from a 2 door Cherokee.
This truck runs and drives great. I just bought it about 2 months ago and have a lot planned for it. It is absolutely 99.8% rust free. The odometer/speedometer does not work but the last mileage was around 176k. Unknown if that's to the donor Cherokee or mine.
This Comanche is happily residing in Central FloridaIMG_20220430_114313936.jpg.767a5b9b292216608f424e4c6347886f.jpg
*B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT
-H9
174 Zone 74-Denver
1AA U.S. Dealer Retail
5AL Low Series Tracking
ADL Skid Plate Group
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Maint. Free Battery
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDX 5-Speed HD Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ Dana 35 Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAA Instrument Panel
JAY DO NOT USE - See JP, KA classes
JBF Instrument Panel Black Bezel
JCA 85 MPH Primary Speedometer
JGB
JHA Var Intermittent Windshield Wipers
JKB
K3Z STRIPE/BADGE/MOLDING/COLOR
KDD
LAF Seat Belt Alert-Driver Seat only
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MLDG - TYPE I
NAF High Altitude Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PWB PAINT -HWB
QWB PAINT - HWB
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Steering
SCB Steering Whl
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
WJK 15X6.0 Styled Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
XEE Fuel Tank Skid Plate Shield
XEF Transfer Case Skid Plate Shield
XEU Front Suspension Skid Plate
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z62 Left Front Spring Group XI
Z81 Right Front Spring Group X
Build date 8/11/88
Body code JL61
Sold by MEAD CLASSIC MOTORS INC, GRAND JUNCTION CO
-H9
174 Zone 74-Denver
APA Monotone Paint
BCX Dual 700 Amp Maint. Free Batteries
DRJ Dana M235 Wide Rear Axle
EAA All Engines
GUA Open
JGB Performance Data &&&& Video Recorder
JKB MOPAR Hood Lock
KDD
LBC Glove Box Lamp
MBJ Black Powder Coated Front Bumper
MFF Black Grille
MMG Belt Moldings
PWB PEARL WHITE PRIMARY PAINT - HWB
QWB PEARL WHITE SECONDARY PAINT - HWB
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
TAA All Tires
XBS Pickup Box
Build date 8/11/88
Body code JL61
Thank you sir! With the build date being that early in 88, would it technically be an 88 or just a very early 89 in your opinion?
1 minute ago, eaglescout526 said:
No, its still an 89. The KL in the beginning of the last 8 designates it as an 89 model year MJ. I know its not an AMC made MJ but its still damn near close enough.
That's so cool. Thank you again, I really appreciate it. Love learning more about the mystery of this truck
I went through and edited out the common errors and reused codes for ya. :L:
