JD1 Posted April 17, 2022 Author Posted April 17, 2022 Just now, Jim Dohanick said: Anybody know what key set will work for ignition and doors?
jdog Posted April 17, 2022 Posted April 17, 2022 1 hour ago, Jim Dohanick said: Anybody know what key set will work for ignition and doors? amc used two keys like gm, they didn't go to a single key till after chrysler took over. are you looking to replace all with the double keys or single key for all?
fiatslug87 Posted April 17, 2022 Posted April 17, 2022 These are the correct keys, make sure the ignition key (square) has a “J” on it. eBay link One key cannot be used for both ignition and door in factory configuration.
jdog Posted April 17, 2022 Posted April 17, 2022 3 hours ago, fiatslug87 said: One key cannot be used for both ignition and door in factory configuration. For 89 year yes, but he could swap everything over from a 93-94 cherokee and get a single key for all
JD1 Posted April 18, 2022 Author Posted April 18, 2022 Okay, thanks for the info, I’ve got an ignition that the key is stuck in. Was thinking of replacing key cylinder and door locks at the same time.
