1J7FJ26SXML625051
snakedoc67
Build: 6/5/91
Body: jl61
Selling Dealer: OMSC - RTE DE LA GLANE107
FRIBOURG SWITZERLAND
APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes DGSS 4-Speed Automatic AW4 Transmission
DHAS Lock-Up Torque Converter DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle
DMDS 3.55 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows
GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass
GUAS Open JAZS DO NOT USE - See JP, KA classes JCAS 85 MPH Primary Speedometer
KDPS STRIPE/BADGE/MOLDING COLOR KWAS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR
LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper
MFFS Black Grille MHBS Fender Flares MMCS Rear Door Solid Window Insert
MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions
NBKS EVAP Control System NF2S 18 Gallon Fuel Tank QB3S Blue
SCES Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers
TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels XBSS Pickup Box
YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AVS Export O.M.S.C. U.S. Specifications
105S Zone 05-Chrysler Military Sales
*D4 DESCRIPTION NOT AVAILABLE -Y6   ALA
BAFP 130 Amp Alternator BCDP 550 Amp Maintenance Free Battery CBAP Straight Back Bench Seat
CKJP Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DHTP Shift-on-the-Fly,P/Time T/Case
ERH 4.0L I6 Power Tech Engine GRVP Left Manual Mirror HAA Air Conditioning
MDAP Front License Plate Bracket PB3 Blue RAAC All Radio Equipped Vehicles
RAB AM/FM Radio RCDP 4 Speakers SBAA Power Steering
TBB Full Size Spare Tire TNCA P195/65R15 BSW AS Touring Tires TZHP Michelin Brand Tires
WLYC All Steel Wheels YCG Satellite Radio Edit Waiver YGAA Without Billable Fuel
Z01P Rear Spring Group I Z66P Left Front Group XV Z82P Right Front Spring Group XI
4EA Sold Vehicle 4FVP Assembly Plant Tracking 4HA Special Scheduling Condition I
4HC Special Scheduling Condition III 8ED Miscellaneous Intl Dealers
  • 3 weeks later...
