Refreshing Door Latches
I recently removed the door latches from my 1991 Comanche. Both sides were gummed up with dirty dried out grease, or what ever lube was used on them. Once removed, a hot high pressure washer was used to clean the latches, then the latches we're soaked over night in ATF fluid. The brittle plastic rod clips were also replaced. Latches are working like new again.IMG_20220130_143642.jpg.7319c9b36a34b3e5feef96e9f6290c94.jpgIMG_20220130_143625.jpg.e2c7a41ee0e5dae6ada931c3f502746f.jpgIMG_0024.jpg.3d2c4690e37f3ae22105f659aa3c5aed.jpgIMG_0026.jpg.53dfa80c8b28f918495d35a122551807.jpgIMG_0027.jpg.40c37ec7461b0fa622f109df1e7ebef7.jpg
1 hour ago, Tactical Bacon said:
Any recommendations on where to obtain new clips for these excluding the dealership wanting $5 a clip?
I bought the rod clips from a local automotive paint and body supply shop. Picked them from an assortment drawer .80 each.
I didn't think to look for big kits of these clips. Did it look a bit like this one? Because this one seems to have the necessary clips in it and then some,
Chrylser Hood Prop and Rod End Assortment,  Compatible with Vehicle Make Chrylser
Yes! You are on the track.
