Lukas Eder Posted January 24, 2022 Posted January 24, 2022 Looking for someone in the southwest Oklahoma area to come out and get an 89 Jeep Comanche running that’s been sitting for about 10 year’s . Will pay cash and gas. If anyone would want to quote me I’d appreciate it 580-339-3656Lukas. TIA
MiNi Beast Posted January 24, 2022 Posted January 24, 2022 Fresh gas and good spark should fire up if its gots oil. .
Lukas Eder Posted January 24, 2022 Author Posted January 24, 2022 Has good spark and fresh gas good fuel pressure in time. Just can’t figure it out and just had a newborn and started a new job with long hours so I don’t have time anymore to mess with her that’s why I’m looking for someone to get her running for me
Lukas Eder Posted January 24, 2022 Author Posted January 24, 2022 Has good spark and fresh gas good fuel pressure in time. Just can’t figure it out and just had a newborn and started a new job with long hours so I don’t have time anymore to mess with her that’s why I’m looking for someone to get her running for me I also put a cps on it as well thinking that could be the issue. When it last ran it started running rough and when it was shut off it wouldn’t start back up.
Lukas Eder Posted January 24, 2022 Author Posted January 24, 2022 I put a crankshaft position sensor on her and still can’t get her to start. Based off what I was told I checked the time and it was good then replaced the crank sensor and still nothing
MiNi Beast Posted January 24, 2022 Posted January 24, 2022 Well it fired and ran a bit after the cps, so I would double check that. And assuming fresh gas you also install a fresh fuel filter, also did you add some sea foam of sorts to clean the fuel injectors.
jdog Posted January 24, 2022 Posted January 24, 2022 Put some oil in the cylinders, with it sitting for so long I bet the rings are stuck
Lukas Eder Posted January 24, 2022 Author Posted January 24, 2022 New fuel filter as well when she came to me the tank was nasty and fuel pump was not working so I put a new tank and fuel pump in. The injectors weren’t misting after I cleaned them so I went ahead and just replaced them. Do you know of another sensor that could cause it to run rough and not start back again?
Lukas Eder Posted January 24, 2022 Author Posted January 24, 2022 14 minutes ago, jdog said: 14 minutes ago, jdog said: Put some oil in the cylinders, with it sitting for so long I bet the rings are stuck Well it turns over the engine isn’t seized. Do you mean like the rings are stuck causing it to not get compression?
Lukas Eder Posted January 24, 2022 Author Posted January 24, 2022 6 minutes ago, jdog said: Yeah I’ll try that thank you
