tarmac2dirt Posted January 3, 2022 Share Posted January 3, 2022 Looking and have searched here through nearly 100 pages here and can 't find my answer. I then went to the naxja web site and found just one answer and wasn't thrilled at all. Can some one verify that the dash pad is or isn't a removable piece. naxja said that it is not removable and is glued to the main dash. Can this be true. not removable ?? i wanted to remove my dash pad and have it redone when i pull the complete dash for a heater core change. Thanks for your time. Paul Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 3, 2022 Share Posted January 3, 2022 You’d have to take it to some place that specializes in such. It’s a vinyl pad glued into place. So the best way to probably remove it is with a heat gun. Even then you’ll risk destroying the pad and possibly warp the dash. There’s one place in Cali I reached out to and got no response from them as to whether or not that can redo the dashes in our MJs/XJs. Link to comment Share on other sites More sharing options...
OldSch88L Posted January 14, 2022 Share Posted January 14, 2022 Yep; plastic frame riveted on a metal cross brace. The foam pad is glued to the plastic and then the vynil is heated, glued and stretched over the pad. Link to comment Share on other sites More sharing options...
