Oizarod115 Posted November 22, 2021 Posted November 22, 2021 Hey Crew, I'm looking for an AX15 mounting plate for an MJ/XJ hope someone has one! if you have it and don't want to sell it I could use some measurements off of it!! Thanks, -Nick
ghetdjc320 Posted November 24, 2021 Posted November 24, 2021 Are you referring to that thin little spacer plate that goes between the bellhousing and the block?
Oizarod115 Posted November 24, 2021 Author Posted November 24, 2021 No, I need the steel plate that bolts to the bottom of the transmission, has studs to put a rubber trans mount, and has the exhaust mount.
Oizarod115 Posted December 21, 2021 Author Posted December 21, 2021 For anyone looking for this in the future, I used the Novak universal AX-15 mount, and had "send-cut-send" make me a plate to go from the 4 hole MJ/XJ mount pattern to the 2 hole Novak mount pattern. Ended up costing 125 total. https://www.novak-adapt.com/catalog/rear-mounts/rmax15-rear-mount Spacing on the 4 hole crossmember mount pattern is 8mm bolts at 65mm wide x 55mm front-back, novak mount is 7/16 bolts spaced 5" wide, the drivers side novak bolt will line up just about where the rear drivers 4 hole pattern bolt is.
Pete M Posted December 21, 2021 Posted December 21, 2021 16 minutes ago, Oizarod115 said: For anyone looking for this in the future, I used the Novak universal AX-15 mount, and had "send-cut-send" make me a plate to go from the 4 hole MJ/XJ mount pattern to the 2 hole Novak mount pattern. Ended up costing 125 total. https://www.novak-adapt.com/catalog/rear-mounts/rmax15-rear-mount Spacing on the 4 hole crossmember mount pattern is 8mm bolts at 65mm wide x 55mm front-back, novak mount is 7/16 bolts spaced 5" wide, the drivers side novak bolt will line up just about where the rear drivers 4 hole pattern bolt is. nice! can you put together a writeup for the DIY section?
