No Longer Needed - AX15 mount plate (details inside)
Oizarod115
  • 4 weeks later...
For anyone looking for this in the future, I used the Novak universal AX-15 mount, and had "send-cut-send" make me a plate to go from the 4 hole MJ/XJ mount pattern to the 2 hole Novak mount pattern. Ended up costing 125 total.
https://www.novak-adapt.com/catalog/rear-mounts/rmax15-rear-mount
Spacing on the 4 hole crossmember mount pattern is 8mm bolts at 65mm wide x 55mm front-back, novak mount is 7/16 bolts spaced 5" wide, the drivers side novak bolt will line up just about where the rear drivers 4 hole pattern bolt is.
  • Oizarod115 changed the title to No Longer Needed - AX15 mount plate (details inside)
nice!  :D can you put together a writeup for the DIY section?
