keedysville Posted October 29, 2021 Share Posted October 29, 2021 1989 Base Comanche 4.0; 5 spd manual (BA-10); Command-Trac; DANA 30; DANA 35; short bed 113" wheelbase Build date is no longer visible on the door sticker Purchased new December 7, 1988 by Paul Kreipe of Tecumseh, Kansas at Ellena Jeep-Eagle, Lawrence, Kansas Currently located in Unionville, Missouri. Current mileage 108,819. This truck is tucked away in the shop awaiting an AX-15 swap, new paint and perhaps an interior swap from a 1989 XJ Limited Options: (See picture of window sticker) Dover Gray, Bench Seat (Canyon fabric), 5 spd, 4.0 litre engine, vent windows, dual remote mirrors full gauges, intermittent wipers, cigar lighter, power steering, tilt steering wheel, conventional spare. Current owner is Brian Keedy Vinyl flooring (no carpet) Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 29, 2021 Share Posted October 29, 2021 *B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT -SA Charcoal 152 Zone 52-Kansas City 1AA U.S. Dealer Retail 4HG Central Scheduling Block 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JGB Performance Data &&&& Video Recorder JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3 QS3 DOVER GREY MET C C SECONDARY PAINT - HS3 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 11/7/88 Body code JL61 Sold by ELLENA JEEP-EAGLE, LAWRENCE KS Link to comment Share on other sites More sharing options...
keedysville Posted October 29, 2021 Author Share Posted October 29, 2021 Thanks EagleScout. More information is always better. I have another one I purchased this past weekend. I'll be putting it in the registry soon. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 29, 2021 Share Posted October 29, 2021 Sounds like a plan! Link to comment Share on other sites More sharing options...
Pete M Posted October 29, 2021 Share Posted October 29, 2021 the MJ addiction is real Link to comment Share on other sites More sharing options...
