Whitaker717 Posted October 9, 2021 Share Posted October 9, 2021 I was looking back through some old threads and couldn’t find it but can someone tell me if the trim going around the windows is removable. I would like to peel off that black coating on them and polish them. Also what is the best way to do it? Thanks Link to comment Share on other sites More sharing options...
ghetdjc320 Posted October 10, 2021 Share Posted October 10, 2021 It is removable. Best way I’ve found to remove the black coating is with a propane torch. Heat the back side of the trim and it will literally fall off. Try not to melt the coating though. If you do, you will have to sand it off. Link to comment Share on other sites More sharing options...
Whitaker717 Posted October 10, 2021 Author Share Posted October 10, 2021 Does it pop off pretty easy? The trim that is. Is there a certain technique that prevents it from bending or just take my time. Link to comment Share on other sites More sharing options...
howeitsdone Posted October 10, 2021 Share Posted October 10, 2021 Not the easiest as over time corrosion builds up, but I take a trim removal tool and get under the bottom piece to lift it up at the edge closest to the rear. From there I grab it and pull up. Might take some force, but make sure to lift UP and not OUT. The rest will be easier since only the bottom piece is held in by 4 metal tabs. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted October 10, 2021 Share Posted October 10, 2021 Agreed. Also make sure not to bend it. It is very thin metal and next to impossible to straighten if bent. Link to comment Share on other sites More sharing options...
Whitaker717 Posted October 10, 2021 Author Share Posted October 10, 2021 Thanks guys! I will give it a whirl. Link to comment Share on other sites More sharing options...
