1989, Jeep, Comanche (Base I believe).
Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase: No Clue Unfortunately but I do know that I have been buying parts for the 1989 Jeep Comanche with O' Reilly's and Rock Auto and so far everything has fit so:
Inline 6 Cylinder 4.0L, believe original Manual Transmission, no clue on everything else.
Build date: (its on the driverside door sticker, in the form of month and year): So this is all been rubbed off over the years.
Current Location: Minnesota
Status: Is it still on the road: It is on the road, currently my daily driver.
Notes: Bought from a Used care dealer in Montrose, CO back in 2013, and have had it ever since, still figuring out what all they did to it, but do know that there is a body/lift kit on it by 3" and started doing upgraded parts when something breaks down on it.
Current owner: Me
*X2 TRIM STYLE X2 - VINYL BENCH
-Q8
174 Zone 74-Denver
1AA U.S. Dealer Retail
5AL Low Series Tracking
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Maint. Free Battery
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDX 5-Speed HD Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ Dana 35 Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEC Front Left Side Sliding Window
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBF Instrument Panel Black Bezel
JCA 85 MPH Primary Speedometer
JKB
K3Z STRIPE/BADGE/MOLDING/COLOR
KDB STRIPE/BADGE/MOLDING
LAF Seat Belt Alert-Driver Seat only
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MLDG - TYPE I
NAF High Altitude Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PB3
QB3
RAA All Radio Equipped Vehicles
RAC AM MTR Radio
RCA Audio
SBA
SCB steering wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC Tires
WJK 15X6.0 Styled Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGB 1 Additional Gallons of Gas
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z65 Left Front Group XIV
Z84 Right Front Spring Group XIII
Build date 10/24/88
Body code JL61
Sold by AUTONATION CHRYSLER JEEP WEST, GOLDEN CO
  • eaglescout526 changed the title to 1J7FJ26L8KL459084 The Blue Bird
Holy smokes, that is a lot more detail than I have ever been able to pull up on Bluebird! Thank you so much, this should help in the search for newer replacements or even upgrades.
most importantly, her 33rd birthday is coming up soon. :D
  • Pete M changed the title to 1J7FJ26L8KL459084
