Looking for good comfort /transmission switch
Whitaker717
If you have fog or the cargo lamps, swap the switch around and test it. If it works, the switch is good. If not well the yes the switch is bad. Rarely do these switches fail, I had one but the prong came off from the back from weak soldering but even then the switch still worked. Does your trans shift at all?
