Wheel and Tire Size *without lift*
Super frustrated trying to figure out wheel and tire size combinations that I can fit on my comanche without lifting it. Seems like it has to stay to the stock back spacing or it will rub since its not lifted.
Any input/feedback would be greatly appreciated.
30 inchers and 235s will fit no problems.  :L:
31s can fit with some caveats (namely the stock rims aren't all the same, and 31" tires aren't all the exact same size)  some tire rub is possible on the lower arms (can be fixed with WJ lower arms)
I ran 17" JK takeoffs for several years at close to stock height with minor rubbing. When I say close to stock height, I mean a 2.5 2wd, converted to 4wd from a 2.8, with an extra isolator added to the spring, and longer shackles in the rear on the 2wd springs for about 1" rear lift or equal to 4wd springs. The JK takeoffs run close to 32" tall.
