Mj restoration
Hi all,
Totally new to the whole Jeep world and more to the Comanche
I was offered an 89 Comanche that is in dying need of restoration
And it's basically got me excited just to make this project and convert an old rusted MJ to a new and renewed beast
But... I was wondering... How hard will it be to get parts?
What parts are compatible to an MJ? For example, Cherokee parts work?
Can I use rubicon parts? (I ask cause I have all the parts of my friends rubicon in storage... Shocks, shaft, links etc..)
Will it be straight forward install or will I have to make adapters and mounts?
Obviously generally speaking without going to details (yet)
Thanks in advance for your help and advice
Generally everything from the A-pillar forward is the same as a similar year XJ.  About 50% of everything B-pillar to A-pillar is the same between a similar year XJ.
The major XJ changeover years were pre86, 90, and 96/97 so for your MJ you'd want to focus on 86-90 for most things.  After 90 the engine management system changed so the electronics will be different, mechanically they are identical throughout 84-96 for the most part.
