WahooSteeler Posted August 1, 2021 Share Posted August 1, 2021 Going to install "The Cure" from Ruff Stuff today, and when I unbolted my tie rod it spun freely in the adjuster sleeeve/clamp on the opposite end where you adjust the length. I'm assuming this should not be the case? I did not install the new components when I upgraded to ZJ V8 units, but I have always been under the impression this was to be clamped down once you've adjusted your tie rod length. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 1, 2021 Share Posted August 1, 2021 5 hours ago, WahooSteeler said: Going to install "The Cure" from Ruff Stuff today, and when I unbolted my tie rod it spun freely in the adjuster sleeeve/clamp on the opposite end where you adjust the length. I'm assuming this should not be the case? I did not install the new components when I upgraded to ZJ V8 units, but I have always been under the impression this was to be clamped down once you've adjusted your tie rod length. It should. The adjuster has a bolt clamp on each end that should tighten up nice and snug to prevent movement Link to comment Share on other sites More sharing options...
WahooSteeler Posted August 2, 2021 Author Share Posted August 2, 2021 27 minutes ago, ghetdjc320 said: It should. The adjuster has a bolt clamp on each end that should tighten up nice and snug to prevent movement I certainly thought so, common sense would suggest that also. Found a vid that said they should be torqued to @14ft/lbs........Done. Link to comment Share on other sites More sharing options...
OldManComanche Posted August 2, 2021 Share Posted August 2, 2021 I have had a couple of Jeeps that someone used a welder to "clamp" the adjusting sleeve. I guess the train of thought is "set it and forget it" Link to comment Share on other sites More sharing options...
