icelandic1 Posted July 14, 2021 Posted July 14, 2021 Hello all Flew back to Regina Saskatchewan towards the end of June from the BC coast, picked this up and then road tripped back through 1500 miles, the Rockies and the heat - ran like a true star and didn't drop a stitch on the way - 3 major mountain passes, started shaking over 100 k's so didn't push it over that drank a little of oil but that's ok - It is definitely a project truck and needs some work to pass provincial inspection here so I'll be looking for bits and pieces once I can access the buy/sell forums here 1989 long box base model (I think) 4wd 4L 5 speed - according to the VIN these have been swapped in from the original build 215,xxx k's on it VIN - 1J7FJ26L1kL429649
icelandic1 Posted July 15, 2021 Author Posted July 15, 2021 thanks for the edit - still finding my way around here - looking forward to being a member
eaglescout526 Posted July 15, 2021 Posted July 15, 2021 *B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT -Q8 121 Zone 21-Canada-Ontario 1AB Canada Dealer Retail 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JDB 180 KPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KWX LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon NHK Engine Block Heater PB3 QB3 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJK 15X6.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAC Build To Canada Mkt. Specifications YGA Without Billable Fuel Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 10/10/88 Body code JL62 Sold by NORTH-WAY CHRYSLER MOTORS LIMI, NEW LISKEARD ON
