jaekl Posted March 24, 2006 Share Posted March 24, 2006 I'm planning a swap a 5 speed from a 4.0 liter to a 2.5 liter with a 4 speed. I know the bell housings will need to be swapped as well, which I believe is possible. The next issue is the input shaft compatibility. Before I pull the trans, can someone confirm that this will work? Link to comment Share on other sites More sharing options...
pingpong Posted March 24, 2006 Share Posted March 24, 2006 We need to know what yr motor and tranny they are from. Also if you check out some of the Adapter companies websites, they can give you a more definate answer then we can. Patrick Link to comment Share on other sites More sharing options...
jaekl Posted March 24, 2006 Author Share Posted March 24, 2006 Both are 1988. Link to comment Share on other sites More sharing options...
Pete M Posted March 24, 2006 Share Posted March 24, 2006 Sorry, but that can't be done. If you had an AX-15, you could use a Dakota bellhousing to mount it up to the 2.5L (at one point in time the Daks used both the AX-15 and 2.5L together), but the 4.0L trans in 88 was the Peugeot and no such adapter bellhousing exists. The 4.0L and 2.5L have different bolt patterns for their bellhousings. Jeep on! --Pete Link to comment Share on other sites More sharing options...
