Mc754sofla Posted June 25, 2021 Posted June 25, 2021 I have a 1987 comanche with rear main seal leak bad and I heard these transmissions are horrible I wanna lower the truck and add horsepower???
cruiser54 Posted June 25, 2021 Posted June 25, 2021 I know I've only had one cup of coffee this morning, but this ^^^ post makes no sense to me........
Pete M Posted June 25, 2021 Posted June 25, 2021 the Peugeot manual transmission isn't going to like any addition horsepower, that's for sure. do make sure that it's the rear main seal leaking, rather than the rear of the valve cover leaking down the back of the engine.
cruiser54 Posted June 25, 2021 Posted June 25, 2021 CRUISER'S MOSTLY RENIX TIPS REAR MAIN SEAL DIAGNOSIS OCTOBER 31, 2015 SALAD 3 COMMENTS I’d be looking up ABOVE first, and VERIFYING the source of the oil leak YOURSELF. Everybody, who doesn’t own or have to pay for or perform your vehicle repairs, loves to poke their noggin UNDER the Jeep and come out bearing the false bad news that your RMS is leaking. Many mechanics, friends, and good old Uncle Bob seem to enjoy telling you it’s the rear main seal. Has a catastrophic ring to it, doesn’t it? A simple leak at the back of the valve cover or other source could produce the same symptoms. You don’t need to be a mechanic to figure this out. If you have good eyesight and a dim flashlight, you’re good to go on your own. Don’t jump on the RMS/oil pan gasket bandwagon right off the bat. Almost any oil leak on your 4.0 is gonna drip from the RMS area for two simple reasons: First off, the engine sits nose-up and any oil will run back to the RMS area. Secondly, the RMS area is also the lowest point on the engine. Simple physics and the old plumber’s adage apply here: “Crap flows downhill”. Valve cover gasket, oil pressure sending unit, oil filter adapter seals and distributor gasket, in that order, have to be eliminated as possibilities first. A little tip here. Rather than use a dizzy gasket, use an o ring instead. NAPA #727-2024. Tips 12 and 13 will help you get your distributor back in place correctly.
