Imgur link
2.4 / ax5 / D35 / Longbed
Build date: n/a sticker completely faded
Current Location: Santa fe NM seems to have traveled here from Oregon around 2018
Status: I've been driving it daily cause why not it seems to run fine to me
Notes: just a stock longbox Comanche was totaled in 2017 and has a rebuilt title. mileage on cluster is almost 100% inaccurate though I'm not sure why someone would have changed clusters.
Current owner: .
does it have a full cluster or the idiot light cluster?  a better cluster can be swapped in pretty easy.
I'm assuming they swapped in the one with actual needle gauges as it does not have idiot lights, and that's why the mileage is off
I do believe there's a thread in the link in my signature that explains how to change the ODO if you'd like to make it something more accurate.  :L:  assuming anyone even knows what is accurate.  :dunno:
Sweet another 2.5L!
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT
-ZZ
CGX Head Restraints-Outboard Seating, RR
DDJ 5SPD MANUAL TRANS
DMN 4.10 Axle Ratio
EPD ENGINE - 2.5L I4 TBI GAS
GSC MIRROR - RIGHT BLACK
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JGB Clock - Digital
JHA WINDSHIELD WIPERS - DELUXE
JJA CIGAR LIGHTER - FRT COMP
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NFA TANK - 23 GAL FUEL
Build date 5/6/86
Body code TL62
