Door question
Yeah they fit the hole just fine.  You have to use the latch from a 97+ on the b-pillar.  Many different ways people have done it such as elongate the hole so it lines up or cutting that area out and welding it in.  Lots of trial and error adjusting it to get it to latch properly but not a hard job.
Everything else about the door is entirely different though so don't expect to swap door panels and such.  Someone took the guts from a 97+ door and put it into a 96- door so it could use the large window.  Looked like a lot of work but was doable.
