Firewall Fuse Panel leak
Fuse panel doesn't seal good against the firewall. Is there a rubber gasket/seal that is missing or worn out on mine? Found out that other than the antenna hole, that is my main source of leaking in rain water. If there is a rubber thing, can I buy any new? Or just have to find one from a junkyard XJ?
It's a small foam seal on the cabin side of the fuse block connector.  I don't think they're available new; I cut a new one out of a closed-cell foam sheet.  You can also use some RTV on top of the foam if you don't ever want to remove that connector ever again lol
