Transmission mount help
70barracuda
Need ideas for a transmission mount for my LS swap and new tremec trans. I'd like to keep the stock cross member if possible. In my head I'm just gonna stack square tube and weld it up. I'm worried itll be too high of a tower if that matters. Ideas???
I would take advantage of the extra clearance and make a new crossmember that was flush with the rails. 2x4 square tube with angle iron on the ends to bolt in the stock holes.
 I bet that would get you pretty close with out looking butch.
